2000 xk8 misfires and resticted performance
Old 03-31-2009, 10:36 AM
KeenStacey's Avatar
Mine did exact same thing (2000 XK8 @ 55k miles). 1st time Jag dealership said only code showing was mass air flow sensor. That shouldn't cause problem but was the only thing he could find. That didn't fix it. Read on forums it was most likely brake light switch. I ordered that part and replaced it myself, which was a job! That didn't fix it. Took it back to Jag. They said it needed a new wiring harness and throttle body. After a total of around $3,500, its fixed. I recently read a post here titled ALERT concerning this. That might be helpful. Good luck!!
Old 03-31-2009, 12:14 PM
Bushels full of apples and oranges. A brake light switch failure will not affect engine performance, and a throttle body TPS failure which will is not going to generate four missfire codes.
Kjanelle, if all four codes are from one bank of the engine, I would suspect that a secondary timing chain has jumped a tooth. You both need a mechanic who is capable of inspecting your engine and diagnosing the fault before replacing anything.
Bcrary3
09-11-2015 10:36 AM
corysansburn
09-10-2015 06:15 AM
Super Cat
09-09-2015 03:24 PM
stype40
09-09-2015 08:14 AM
XFR_Gold
09-02-2015 12:24 PM
Quick Reply: 2000 xk8 misfires and resticted performance
