2000 XKR Transmission Fluid & Filter Change
Old Jul 22, 2015 | 10:55 AM
80sRule's Avatar
Default 2000 XKR Transmission Fluid & Filter Change
Last night was perfect weather and I did a bunch of stuff on my XKR. This was one of those jobs.
I bought:
-Duralast TF178 Transmission Filter $17 at Autozone (LINK)
-2x 4qt Valvoline MaxLife ATF $40 at Autozone (LINK)
-1 722.6 Dipstick, bought a long time ago but about $8 (LINK)
What tools:
-1/4 and 3/8 Drive Ratchets
--5mm Allen socket/key/whatever
--5mm Torx socket/key/whatever
-IR Thermometer (borrowed a Fluke 62 MAX IR Thermometer)
Steps:
This guide is almost dead on:
Pelican Technical Article: Mercedes Benz - Automatic Transmission Fluid Change
This is a very easy job. This is so much easier than the ZF units I've worked on. The pan gasket is quite clever too; this is a very straightforward job.
Old Jul 24, 2015 | 05:54 AM
jamdmyers's Avatar
You might have considered replacing the electrical coupler o rings, these will eventually leak on this transmission, one of only 3 problems we'll possibly see. You'd drain fluid, pull coupler and throw on 2 o rings.
Old Jul 26, 2015 | 09:34 PM
Dr. D's Avatar
My understanding is that only the coupler with included o rings is available now. Is there a source that sells just the o ring kit or separate o rings?
Thanks.
Old Jul 27, 2015 | 07:29 AM
jamdmyers's Avatar
Thanks.
I believe you can get them through Mercedez
toronadomike
Jan 22, 2026 10:13 PM
Sprayall
May 30, 2021 08:13 AM
Beardy
Sep 18, 2015 10:00 AM
Sprayall
Sep 3, 2015 07:49 PM
XFR_Gold
Sep 2, 2015 12:24 PM
