2000 XKR / XJ8 differential comparison
Old Dec 10, 2015 | 10:24 AM
orlmel2007's Avatar
Default 2000 XKR / XJ8 differential comparison
Hi all! As always, Thanks for all your help.
How does the 2000 xkr and xj8 differential compare? I found a unit from a 98 xj8. Can I exchange the driveshaft flange, modify the shaft on the pinion on the xj8 by cutting it off?
Old Dec 10, 2015 | 04:25 PM
motorcarman's Avatar
YES
Old Dec 11, 2015 | 04:12 AM
orlmel2007's Avatar
YES
Thanks for your reply motorcarman. So both units are identical with the exception of the pinion & flange? Has someone else, that you recall, performed this mod with positive results? Thanks again!
Old Dec 11, 2015 | 08:07 AM
homebeforedark's Avatar
I replace the differential assembly in my 2002 XKR100 about three months ago. Like you,I found one that was set up for a donut instead of a flange. I cut off the snout and installed the flange from the broken diff. I wanted to just replace the ring and pinion but could not find the pieces. Supposedly it is a DANA unit actually made by *** in Germany.
dooj65
Nov 29, 2016 10:50 AM
Scotsaltire
Apr 18, 2016 03:49 AM
Scotsaltire
Dec 15, 2015 06:56 PM
fourlcars
Dec 7, 2015 06:35 AM
JayCee
Dec 3, 2015 01:57 PM
