2001 xk8 GOT DETAILED NOW ISSUES
Old Sep 26, 2016 | 09:18 PM
rsims's Avatar
Default 2001 xk8 GOT DETAILED NOW ISSUES
Hi all,
BEEN AWHILE SINCE i WAS HERE,
HAVE A 2001 XK8. HAD IT DETAILED AND NOW ITS IN LIMP MODE...??
What can I look for, I see No water standing anywhere. Car starts right up , has Mis and will not move in Drive.. Reverse Yes..
RS
Old Sep 26, 2016 | 09:21 PM
Jandreu's Avatar
Sounds like maybe they sprayed water where they should not. Did they wash the engine bay? Any codes?
Old Sep 26, 2016 | 09:37 PM
rsims's Avatar
They didn't detail the engine bay..?? But the hood was open a little bit. So Yes water got to something but WHERE?
It just happened so tomorrow I will get codes...
Old Sep 27, 2016 | 01:57 AM
03 XKR's Avatar
If the hood was open, water could have gotten into the two covered boxes in the bulkhead extension, which contain fuse and relay enclosures, or further down the driver's side into the fuse box and connectors between the ABS Module and Shock Tower. You might try compressed air and electronics cleaner to dry out any water that cannot be seen and clean the plugs and connectors, do this with the battery disconnected. If you have a garage with heat, I would raise the heat and open the hood and lids to help dry things out if water is the problem. The following document shows the location of the fuse panels, fuse function and relay charts. The relevant information begins on page 4-12.
File Type: pdf
Old Sep 27, 2016 | 02:08 AM
Datsports's Avatar
check the TPS plug.
Daim
Mar 26, 2024 04:43 PM
AlexJag
Aug 30, 2019 02:30 PM
jeffwilson34
Sep 29, 2016 02:27 PM
graham11
Sep 26, 2016 07:52 AM
ghrim6262
US Midwest
Sep 25, 2016 11:26 PM
