2001 XK8 Radio Power Missing
Old Sep 17, 2015 | 11:58 PM
pilot435's Avatar
Default 2001 XK8 Radio Power Missing
Hi, I do not have power to my 2001 XK8's Radio/Cassette Player.
Power at fuses and fuses good. Have power to Power Amp and Not missing power to anything else (that I know of).
Has anyone had a similar experience or any ideas?
Thanks in advance.
GW
Old Sep 18, 2015 | 02:30 AM
Welcome to the forum pilot435,
I see you've been a member since December 2013 but this is your first post.
Eliminating the obvious one - the rotary VOLUME switch on the head unit is PUSH to power ON and OFF. You certainly wouldn't be the first to miss this.
Old Sep 18, 2015 | 07:30 AM
jimforrest (uk)'s Avatar
I have the same problem Pilot - but can't help with a solution.
I think the + & - got crossed over once (for a fraction of a second) when jump starting the car and the radio has never powered up since.
Old Sep 18, 2015 | 07:38 AM
WhiteXKR's Avatar
The common problem when jump jump starting this car is starting using another car that has its engine running. This causes malfunction of the voltage regulator, and typically the radio is the first victim. That is why the owners manual specifically states that the donor car must not be running.
Used headunits are available on eBay for a fairly reasonable cost if all else fails.
Old Sep 18, 2015 | 09:04 AM
Yep - you're dead right White. But we all do RTFM (after it's blown up!)
I have bought a radio but haven't bothered to install it yet. By the way - many advertisers say the XJ & XK radios are the same, but they're not because the front panel is a different shape.
Old Apr 8, 2016 | 06:16 PM
pilot435's Avatar
Thanks for the suggestions. I've been on another project so this fell to the bottom of the list. I just got a replacement radio and will install soon. Regards
Gordon
1997 XK8 Conv.
toronadomike
Jan 22, 2026 10:13 PM
philwarner
Oct 4, 2024 01:37 PM
99xk8guy
May 28, 2024 09:36 PM
skadmiri1
Sep 9, 2015 11:27 AM
TexasCat
Sep 8, 2015 04:36 AM
