2001 XKR low coolant light - RESOLVED
Old Jun 4, 2020 | 01:13 AM
brinny's Avatar
Default 2001 XKR low coolant light - RESOLVED
Hi all, I've changed the water pump on my xkr and after topping the coolant up the warning light is still on? Any suggestions?
Last edited by GGG; Jun 4, 2020 at 06:05 AM. Reason: Add "RESOLVED" to thread title
Old Jun 4, 2020 | 01:54 AM
DavidYau's Avatar
The coolant sensor works as a magnetic donut float, on a stick, in the expansion tank reservoir. There's a common problem, where you've drained the coolant, and the donut float is dirty and stuck to the bottom of the stick. Possible Quick fix - stick a magnetic pencil thingy into the back/bottom of the coolant reservoir and try to release the float.
BTW are you sure you have a good battery charge, as this low voltage causes all sorts of funny errant warning messages?
Old Jun 4, 2020 | 03:16 AM
brinny's Avatar
Thanks for the info david I didn't know about that and haven't seen anything in the tank as such so will try it. Battery is good and is on a conditioner. Light wasnt on before.
Old Jun 4, 2020 | 05:19 AM
aeginc77's Avatar
I had the same problem after changing the coolant. It takes a long time to get all the air out of the system even after you squeeze the hoses. I finally solved the problem by disconnecting and bypassing the low coolant light from the expansion tank. It was either that or replace the expansion tank which includes the senson. I'm much happier now not seeing that light come on when I know the radiator is full!
Old Jun 4, 2020 | 05:24 AM
The Fluid Level Sensor is available separately (P/N LNA5740AB) and clips into a tube in the bottom of the Expansion Tank.
The Expansion Tank comes complete with Fluid Level Sensor and Pressure Cap.
Old Jun 4, 2020 | 05:57 AM
brinny's Avatar
Sorted. After David's reply I had a look at the part then as soon as I got to the car I could see it. I must have pulled it out when moved the tank to do the cam covers. Replaced and no light. Many thanks for the help to you all
david i
Jun 13, 2022 05:36 AM
aeginc77
Mar 10, 2021 04:06 PM
srpope80
Nov 13, 2015 11:07 AM
hughey
Aug 18, 2009 02:27 PM
