2001 XKR oil cooler
Old Sep 7, 2012 | 08:10 PM
raphell's Avatar
Default 2001 XKR oil cooler
I have removed all four retaining nuts and onhooked both lines. Now how do I get the cooler out? There doesn't seem to be any way to remove it from the brackets.
Old Sep 7, 2012 | 09:17 PM
BlackX300VDP's Avatar
That should be it. Are the brackets bent? That usually happens on those oil coolers. the brackets should be level to the ground.
Old Sep 9, 2012 | 12:20 PM
raphell's Avatar
So the nuts should face the ground? Mine kind of face the front so the cooler would have to go into the radiater to come off. Should I just pull on the top of the oil cooler to straighten it up? I really appreciate your help. I am hoping that a radiator shop can fix my cooler so I don't have to get a new one.
Old Sep 10, 2012 | 07:03 AM
You are correct, the nuts should be facing the ground. Just bend the brackets back so they are level with the ground and out she comes.
toronadomike
Jan 22, 2026 10:13 PM
99xk8guy
May 28, 2024 09:36 PM
GordoCatCar
Jan 2, 2017 01:10 PM
Scarecrow
Mar 28, 2016 03:17 AM
skadmiri1
Sep 9, 2015 11:27 AM
