2002 XK8 Convertable - Replacing seals for convertable top to driver door window
Old Apr 20, 2011 | 05:53 PM
TDBaker's Avatar
Default 2002 XK8 Convertable - Replacing seals for convertable top to driver door window
Wondering if anyone can tell me the proper procedure to remove / install the 3 seals on the convertable top to driver door window. The middle one ripped so, I figured I would replace all three pieces to keep water and wind noise outside. Thanks
Old Apr 20, 2011 | 08:32 PM
cpm53's Avatar
I`d be interested in this one also, if anyone has a procedure for this...
Old Apr 20, 2011 | 09:57 PM
test point's Avatar
I have only removed the driver door window section but it is a no-bainer. Remove one screw, pull the rubber out of the molded metal frame and it is glued for about an inch at the end. It pulled loose easily.
Old Apr 21, 2011 | 01:10 AM
H20boy's Avatar
I've replaced the middle section...no glue at all, just snug on the 'rail' thingy. Are you sure you want to do all three..its like $100 for each piece!?!?! There is a thread talking about conditioning the older seals - Gummi pfleg, and I bought some...great product, I think it really works! My windows have quieted down noticably. I did about three treatments over a couple days. Still plenty left in the bottle.
Old Apr 21, 2011 | 06:53 AM
test point's Avatar
Default test point wax paper
The front section is $140 alone. That is why I took mine off and sorta 'restored' it with super glue and RTV sealant. See the discussion in the 'Hints from Heloise' sticky. https://www.jaguarforums.com/forum/x...acement-50653/
Old Apr 21, 2011 | 07:01 AM
TomServo's Avatar
I hope the seals on the newer XK last longer
Tom
Old Apr 21, 2011 | 10:24 AM
TDBaker's Avatar
Thanks for the feedback. True enough that each piece is real expensive. I will try the Gummi pfleg on the front and rear pieces and see if I can get away with replacing only the middle piece.
Old Dec 30, 2011 | 02:25 PM
stevepaa's Avatar
Okay, where can you find that rubber for $140? Dealer wants $312.
Old Dec 30, 2011 | 11:32 PM
oldjaglover's Avatar
Sick, isn't it.
Old Dec 31, 2011 | 11:38 AM
pophen's Avatar
TDBaker, My rubber seals were torn in my '98 XK8. I was able to crazy glue them back together that was 2 years ago and 24K miles with many top ups and downs. Jack
Old Dec 31, 2011 | 06:21 PM
stevepaa's Avatar
my seals are torn and i could probably glue them together but the window has folded the lip onto itself and distorted the rubber so I can not reshape it.
Old Dec 31, 2011 | 06:48 PM
test point's Avatar
Sure you can!
Supper glue, dowel wrapped in waxed paper, and heat gun.
Mine was crimped over and torn. Putting it back into position with superglue around the dowel and then warming it worked.
Heloise
Old Jan 1, 2012 | 03:00 PM
stevepaa's Avatar
hum,
in the first pic you can see how window has deformed it.
in the second pic the lip on mine looks like it was torn and some rubber missing There is not much to try to reshape
Attached Thumbnails 2002 XK8 Convertable - Replacing seals for convertable top to driver door window-img_3390.jpg   2002 XK8 Convertable - Replacing seals for convertable top to driver door window-img_3394.jpg
Old Jun 27, 2013 | 02:37 PM
newtcopa's Avatar
Default window seal needed
I need the middle seal passenger side if anyone has one available. thanks.
hafren
Aug 30, 2023 03:42 PM
montypeek
Sep 6, 2015 04:57 PM
frankc
Sep 1, 2015 04:41 AM
roumor
Aug 28, 2015 01:02 PM
brent65622
Aug 26, 2015 08:41 AM
