2002 XK8 coolant leak
Old Jan 7, 2009 | 07:36 AM
trollsdad's Avatar
Default 2002 XK8 coolant leak
My 2002 XK8 has a strange coolant leak, under pressure no leak can be found however when the car is stopped after driving I notice a small puddle of coolant under the engine.
The engine was rebuilt last year with new top and bottom work.
Anyone had the same problem?
Old Jan 7, 2009 | 04:29 PM
hlgeorge's Avatar
Default RE: 2002 XK8 coolant leak
You've got one of those slow leaks that when the engine is hot, it evaporates. When sitting and the engine is cold, it will make its way to the ground. Check around the thermostat housing first.
Rivguy
Dec 4, 2020 07:55 AM
jimmiejag
Sep 9, 2015 02:56 PM
OkieTim
Sep 8, 2015 04:48 PM
Xkr x100
Sep 6, 2015 08:50 AM
OkieTim
Sep 2, 2015 12:48 PM
