2002 XK8 misfire
Old Oct 13, 2022 | 12:23 PM
Ryder75's Avatar
Default 2002 XK8 misfire
Please help !
I’ve recently took ownership of my first Jag . The car has been stood for 10 years plus . I’ve managed to get it running but I’ve got a misfire at about 2500 rpm once warm ( cold it revs fine ) . I have changed the up stream O2 sensor on the LHS side ( looking from the front ) . This made no difference, so I’ve changed the plugs and still no difference. Any help would be appreciated. Thanks 😊
Old Oct 13, 2022 | 02:12 PM
NBCat's Avatar
If the engine is being revved without load, the PCM does not allow the engine to go beyond ~3000 rpm to reduce the possibility of damage to the connecting rods.
Use a smart phone with the Torque app to connect to the PCM via the OBD port using a Bluetooth interface to read the fuel pressure. The fuel pressure at idle should be between 300 to 330 kPa.
Old Oct 19, 2022 | 10:45 AM
jrnsr's Avatar
We have to assume the Check Engine Light is on, so get an OBD2 scanner or take it to local car parts store to read the error codes if it is licensed to drive. Report back with codes.
Make sure battery is fully charged or stick a charger on it for max voltage at startup.
Old Oct 19, 2022 | 08:10 PM
RJ237's Avatar
It would help to know where in the world you are located.
Kyle Considine
Oct 29, 2018 04:37 PM
Scudboyz
Jun 19, 2017 12:55 PM
jmann324
Dec 17, 2014 01:52 AM
