2002 XKR
Hello Everyone,
New member with a couple of questions about my 2002 XKR. Would like to swap out my double 5 wheels for Hydras. I have not been able to find a definitive answer on whether this is possible. Second I came across a site, TheJagWrangler, that provides a kit to replace the factory temperature idiot needle with a working temperature gauge. has anyone done the installation? Thanks for your help.
Hello Everyone,
Nearly all of us have done the installation. It is a quality bit of kit. I highly recommend TheJagWrangler's RealGauge. He is a forum member as well. It is also easy to change your wheels to Hydra's. Those are the ones on my car. All you need is the source the wheels. They are 18's, which I think the Double Fives are as well, your current tires probably fit.
Thank you giandanielxk8. My hesitation about the Hydras is that every source I have found lists them as being for the 03-06 XK8s. Is this only because it wasn't a factory option in 2002? But will fit on the car? Thanks.
