2003 XK8 Auto Head lights not working after mirror install
Old Jan 17, 2015 | 05:29 PM
brgjag's Avatar
Default 2003 XK8 Auto Head lights not working after mirror install
Today I finally got my rear view mirror back on the jag. Mine has the Compass and dimming mirror. Well all that is working but the auto headlights turn on and off is not working. The eye is not blocked after putting on the mirror. I made sure the connections clicked together then I put the mirror back on. I put the head light switch on auto, but nothing. Mirror/eye for this function has been off got a while. Is there anything I need to reset or is something just broke? I can live without them just thought they would have worked as we seem too recall they did before the mirror fell off months ago.
Old Jan 18, 2015 | 06:29 AM
It should just be a simple plug-in. It's not like the window limit switch reset after a battery disconnect.
1. did you try plugging the broken mirror back in and covering the sensor with a piece of tape to simulate darkness?
2. absolutely sure you were given the correct replacement? There's a P/N change at VIN A36136.
For the rear view mirror with compass display:
to VIN A36135 : C2N2254
from VIN A36136 : C2P1823
Old Jan 19, 2015 | 01:01 PM
brgjag's Avatar
correct replacement what? I put all my orig stuff back on the window.
It worked this morning. Was in the dark garage and it kicked on by itself. Stayed on all the way to work, most other cars still had the lights on also and did not kick on at lunch. is the way to adjust how soon they might kick on and off?? There were times this morning at 8:15 the sun was plenty bright and a few times the sun was right on the window and they stayed on.
Old Jan 19, 2015 | 02:53 PM
I assumed you were replacing a mirror, not refitting the original.
The early ones have a rotary knob on the back to adjust sensitivity.
2003 XK8 Auto Head lights not working after mirror install-auto-headlamp.jpg
This adjuster was soon dropped and there is no adjustment on later designs.
Old Jan 19, 2015 | 03:47 PM
brgjag's Avatar
I just reused my orig mirror. It has came off the window. I cleaned off the tint around the base that had pulled away. Reattached the metal ring to the window, gave it an hour to set then put the mirror back on no issues. Better than paying for a NEW WINDOW with the round metal bracket attached to it which is the only way you can do it the RIGHT way.
Old Jan 25, 2015 | 02:06 PM
brgjag's Avatar
Auto lights handlights are working fine now and even the rain sensor is working though not as sensitive as I would like to see it but oh well, won't us it anyways.
MJ'S Jag
Nov 10, 2022 08:14 AM
johnnie ryall
Oct 19, 2015 09:44 PM
frankc
Sep 1, 2015 04:41 AM
Jandreu
Aug 29, 2015 07:31 PM
gene1
Aug 27, 2015 08:56 PM
