2003 xk8 Code 1647 new owner needs help
Old May 13, 2021 | 10:56 AM
kstevusa's Avatar
There should be a Letter Prefix prior to the number such as P or C. A P1647 indicates a problem with the left (driver)bank front 02 Sensor. If defective, generally members recommend a Genuine Denso replacement. Various vendors on NET have it available less then $100.
Old May 13, 2021 | 10:58 AM
ezorf's Avatar
Just bought a 2003 XK8. Day 2 I have a code 1647 Where can I find the fuse to check with the hope that an easy fix is possible?
is the vehicle safe to drive with this code ?
Old May 13, 2021 | 12:38 PM
flatsix's Avatar
P1647 indicates an O2 Sensor heater malfunction. Most likely its the sensor itself. Causes an emission problem because after cold start it takes a bit longer to get the O2 Sensor on duty.
Depending on the mileage (90.000 +) i would have changed both pre cat o2 sensors.
Fritz
Old May 13, 2021 | 12:41 PM
kstevusa's Avatar
Appears a duplicate thread. I replied to the 1st one.
Old May 13, 2021 | 01:29 PM
flatsix's Avatar
realized that too late, but we mostly have the same opinion.
fritz
NYN8IVE
Apr 6, 2022 07:15 PM
swhitaker
Nov 15, 2017 05:12 AM
JagIan
General Tech Help
May 21, 2016 01:22 AM
emgun
Dec 27, 2014 09:50 AM
