2003 XK8 how do I fix 'asc not available'
Old Feb 10, 2015 | 06:15 PM
akauder's Avatar
Default 2003 XK8 how do I fix 'asc not available'
Old Feb 11, 2015 | 03:08 AM
jamdmyers's Avatar
Welcome to the forums, You might try this link and do a search of the forum these failures have been often discussed, here's 1 link
https://www.jaguarforums.com/forum/x...e-fixed-94566/
Also you will have a Mod come by shortly to ask you to introduce yourself!
Old Feb 11, 2015 | 03:11 AM
Originally Posted by jamdmyers
.......... Also you will have a Mod come by shortly to ask you to introduce yourself!
Welcome to the forum akauder,
The link in post #2 should answer your question.
Old Feb 11, 2015 | 08:23 PM
scardini1's Avatar
AK,
Are you getting the ABS light as well? If so, your ABS sensor connections may be losing contact. In one case, I ever so slightly bent the pins in the sensor, then very carefully re-seated the connector. This ensured a more positive contact. I've also used electric grease to seal the connections. It's been many months since I've had a problem.
I used to clean my sensors every time the problem came up, but then I realized that it wasn't the cleaning that made the problem go away (for a while), but it was merely pushing the connectors back on. Don't even bother to take your tires off. Just reach in there and push those connectors home a bit. If your problem goes away (for a while), you've nailed down the cause. Then just refine the solution.
99xk8guy
Sep 29, 2025 10:51 PM
99xk8guy
May 28, 2024 09:36 PM
Shawn Svacha
Nov 4, 2019 02:47 PM
neruda
Oct 18, 2015 01:19 PM
David Thompson
Sep 3, 2015 07:48 PM
