2004 Jaguar XKR Down Pipe Heat Shielded
Old Jul 12, 2018 | 11:03 PM
mvsbraga's Avatar
Default 2004 Jaguar XKR Down Pipe Heat Shielded
Does anyone know where I can find the left side down pipe heat shield? It is not available any longer and the last new one in existence just sold on eBay. The Jaguar part number is C2N1200. The piece bolts to a bracket that bolts to the exhaust manifold Cat connection. You have to remove the coolant recovery tank to access it.
I
New or used. I have attached a sketch showing it as #8 and a photo showing where it attaches.
Last edited by mvsbraga; Jul 12, 2018 at 11:06 PM. Reason: Add additional description.
Old Jul 12, 2018 | 11:07 PM
mvsbraga's Avatar
This heat shield also has a key hole like cut out to allow it to go around the 02 Sensor.
Old Jul 15, 2018 | 01:49 PM
oldmots's Avatar
You might try Coventry West in Atlanta. They have a big wrecking yard.
Old Jul 15, 2018 | 01:59 PM
mvsbraga's Avatar
Thank you for the heads up. On their web site Coventry says not in stock, but I have sent them an email. Most part houses say NLA so will be a used part if found or make up some sort of replaceable substitute.
JigJag
Dec 6, 2019 02:50 PM
ln69bt
46
May 26, 2018 01:39 PM
Doug
Nov 6, 2016 03:45 PM
jal1234
Jul 27, 2016 06:27 PM
