2004 XKR convertible won't start-handbook needed
Old Feb 11, 2018 | 09:49 PM
kiril's Avatar
Unhappy 2004 XKR convertible won't start-handbook needed
hi there,
I read a few other posts about jump starting a xkr and honestly I got confused--is my battery in the trunk? When I jump start it, the other running car should be turned off but I can try to turn over my XKR after about 5 minutes of jump starter cable connection? Also, does anyone have an updated link to download the 2004 handbook that comes with the car? Mine got stolen which is why I was trying to figure out the proper way to jump start it as I am petrified of juicing the sensitive electronics given all the other posts I've read.
thanks in advance for any suggestions or link forwards.
Old Feb 11, 2018 | 11:31 PM
Johnken's Avatar
Yes your battery is in the trunk. Doner car engine on. Jaguar ignition off.
Connect batteries, let's running car charge jag's battery. Give it a minute or 2, start jaguar.
Old Feb 11, 2018 | 11:34 PM
bakntyme's Avatar
The battery is in the trunk. Here is the jumpstart procedure, courtesy of Norri the Moderator. Be sure to carefully read the "Cautions".
https://www.jaguarforums.com/forum/x...6/#post1832158
Old Feb 12, 2018 | 02:38 AM
Originally Posted by kiril
..... does anyone have an updated link to download the 2004 handbook that comes with the car? .....
Welcome to the forum kiril,
All the XK8/XKR handbooks (Vehicle Document Sets) from 1996 to 2006 are available for download from here:
https://www.jaguarforums.com/forum/x...006-faq-67827/
The correct one for your 2004 XKR is JJM 18 02 14_601. In the Roadside Emergency section you will find the procedure for jump starting.
To locate the battery, first remove the floor panel covering the spare wheel (arrowed in red):
Next remove the RH side trim panel (arrowed in green) to reveal the battery.
Nov 5, 2025 09:03 AM
kiril
Feb 12, 2018 06:01 AM
benfbrown
Jul 8, 2017 07:36 AM
dceckel
Oct 10, 2015 04:57 PM
