2005 XK8 ABS sensor wire harness replacement
Old Jan 12, 2016 | 03:40 PM
zidjan's Avatar
Default 2005 XK8 ABS sensor wire harness replacement
Hi guys, I am getting C1145 which points out to front right wheel sensor open circuit....according to the reading in this forum it's most probably my wire harness...because it's intermittent.
So is there an instruction on how to replace it... I know it's just plug and play but it's better if there's an instruction somewhere.
Old Jan 13, 2016 | 02:56 AM
jimbov8's Avatar
Yes it is plug and play but if it is intermittent then try cleaning the sensor first and the connections before you start looking at the loom.
May save you a few pennies.
Old Jan 13, 2016 | 11:28 AM
fmertz's Avatar
You might want to check on availability also. From memory, I seem to recall reading on this forum that some of those wires were no longer available from Jaguar, so folks were fixing theirs instead.
Old Jan 13, 2016 | 12:02 PM
zidjan's Avatar
I got lucky I bought a new pair on Ebay..someone totaled their 2006 xk8
LJG3410AC and LJG3410FC for $120 for both.
Old Jan 13, 2016 | 12:03 PM
zidjan's Avatar
I cleaned the sensors last summer...can't be that fast for them to get dirty again can it? well worth a try I guess.
Old Jan 13, 2016 | 12:14 PM
fmertz's Avatar
You could also swap the sensors, left to right, and see if the error "moves" with the sensor, or stays put with the harness.
simongulliver
Oct 5, 2023 03:11 AM
King Charles
Sep 13, 2016 09:46 PM
Jugular
Jan 3, 2016 09:32 AM
thedugger1
Dec 16, 2015 06:16 PM
S-type 2000
Dec 16, 2015 06:53 AM
