2005 XKR Mass Air Flow Sensor
I have replaced the mass airflow sensor 3 times, and it keeps giving me the same code, replaced the filter as well. Runs fine for a day or 2 then performance issue and engine light. Any ideas
I've deleted your two identical posts of this same question in X150 forum.
Check integrity of connector first. If that is OK, then, as Stran0020 suggests, it could be un-metered air getting into the intake pipe.
Some leaks are impossible to see and difficult to hear (especially if they are in the concertina type expansion part).
To be sure, your best option, is to remove the intake pipe from the car - between MAF sensor and Throttle body. Then block one end and fill with water. Observe for water leaks which will usually reveal compromised air-tightness.
If all good, then ensure the pipe is dry before refitting !.
