2006 XKR Blowing Brake Light Fuses
Old May 7, 2018 | 09:32 AM
Moseleykmc's Avatar
Default 2006 XKR Blowing Brake Light Fuses
2006 XKR Victory ‘vert; Three years ago, I got the “check rear lights, cruise not avail” message, replaced the brake light switch as most of us have, and things have been fine until now. I just got a different message “check rear lights”, found only the third brake light working. I located a blown 5A fuse, replaced the fuse, got brake lights once, and found the fuse blown again. As the third light still works, I would think the problem is not the switch again? Any ideas on where to start tracking the cause would be appreciated.
Thanks!
Old May 7, 2018 | 10:12 AM
Jon89's Avatar
Clean and burnish your brake light bulb sockets. Then check your ground for a good connection....
Old May 7, 2018 | 10:54 AM
RJ237's Avatar
Check the wires for a short due to chafing.
WinterJag
Aug 17, 2013 07:33 PM
filoli1993
Aug 10, 2012 03:34 PM
abs9692
May 22, 2011 07:04 PM
Dav1d
Jan 15, 2011 07:27 AM
Jagtastic
May 16, 2010 05:23 PM
