2006 xkr message display lights not visible.
Old May 27, 2023 | 09:36 AM
Sacho's Avatar
Default 2006 xkr message display lights not visible.
The message center was working on and off . Now it’s only visible barely with a picture from iPhone. Any ideas , . Thank you
Old May 28, 2023 | 02:36 PM
Johnken's Avatar
Message center
Can you cycle through categories:
Elapsed miles
Instant mileage
Avg speed . . .?
I had a wire get loose at bottom of turn signal stalk that prevented selection at times. Ez solder to fix, but I can't tell if you battling user selected messages or system status displays.
If the later, if sure be interested if the red warning light works when text display doesn't (open hood/bonnet; open drivers door . . .)
Guess we need more details friend.
John
Old May 28, 2023 | 02:58 PM
Sacho's Avatar
Yes all the red lights work. And I can cycle through just very dim. I will check for loose connections. Does the steering wheel have to come off to get to the stalk.
Old May 28, 2023 | 10:14 PM
Johnken's Avatar
Dim? Are you looking at it in daylight with headlights on? That for example, is the one drawback i have using auto headlights as daytime running lights (pretty much a safety necessity with the dam anthracite gray paint job) headlights on = message display dims a lot!
I don't think the rotary dim switch on steering column affects message display.
I am sure your wires are ok. Bad connection <=> no display, never = dim display partner.
So, now I understand much better. Message display works, just very dim. Let's eliminate headlights (or running lights) on first.
If you look and see: no, stalk set to off, just for the hell of it do 2 things:
1. Press front fog light on button. If it shows on, car thinks running lights are switched on!
2. Start car. Look at running lights/headlights. On or off? Stranger things have happened with failed headlight switches.
John
Old May 29, 2023 | 08:36 PM
Johnken's Avatar
You know, I should explain <=>. I used Visual Basic (programming language) for so long, sometimes I default to using it as a shortcut. This means "only equals" or can only be.
John
Old May 29, 2023 | 08:58 PM
Sacho's Avatar
Yes I understood your post. Thanks
IvanDK
Nov 20, 2021 01:55 PM
Sacho
Aug 26, 2021 12:15 PM
MarkJag
Jun 17, 2015 01:24 PM
jagpro69
May 23, 2009 09:34 AM
