Message center illumination not working
Old Nov 9, 2021 | 10:36 AM
IvanDK's Avatar
Default Message center illumination not working
Hey I've recently replaced all the lights in the dashboard, but after the change the message center lights doesn't work. It isn't a burned socket because I swapped it with another. Everything else works fine, some suggestions would be greatly appreciated!
Old Nov 9, 2021 | 07:17 PM
Addicted2boost's Avatar
It’s likely that the socket “tangs” may not be making a good connection. Did you use an led bulb or incandescent bulb? If you have an ohm meter, you could take the socket back out (with the bulb still in place) and use the meter on both of the tangs to see if you a low resistance or open circuit.
Old Nov 10, 2021 | 12:33 PM
IvanDK's Avatar
Thank you for the reply, the bulbs are incandescent, and yea it was bad connection. Have a great weekend!
Old Nov 20, 2021 | 01:55 PM
octabero11's Avatar
I am running into a bit of a problem. When I launched my computer today my GPU RGB was not working. Opening up dragon centre showed that Mystic light was not present. I have tried to update the mystic light patch. But I get this message (image). Clicking ok tells me that the package is not valid installation package and to try and find a Kodi nox folder I can install from.
Sacho
Aug 26, 2021 12:15 PM
warren8959
Oct 22, 2020 05:25 AM
MarkJag
Jun 17, 2015 01:24 PM
jagpro69
May 23, 2009 09:34 AM
blackcloud71
Jan 21, 2008 04:41 PM
