2006 XKR trip mileage, A and B
Old Jul 15, 2011 | 12:07 AM
Mike14k's Avatar
Default 2006 XKR trip mileage, A and B
Hi folks... you were so nice to help a newbie with his tire/wheel question.... now more questions:
My 2006 XKR has a funny issue. The dash control panel for the A/B trip mileage, etc.. seem stuck on the "A" setting. Nothing I push resets the trip mileage (in either "A" or "B") it or changes it to "B".
Thoughts or comments ????
Old Jul 15, 2011 | 07:05 AM
WhiteXKR's Avatar
Do any of the other buttons on the A/B trip pod work?
Old Jul 15, 2011 | 08:40 AM
Mountaincat's Avatar
Press the "000" switch and hold for three seconds---see pg. 4-18 of your owners manual for details.
Old Jul 16, 2011 | 12:23 AM
Mike14k's Avatar
I've been out of town..... Just went to the shop and checked. The buttons on the A/B mileage do nothing; no reset, no "A or B"
Got me scratching my head a bit. Anyone have thoughts ??
Old Jul 16, 2011 | 07:11 AM
WhiteXKR's Avatar
Try this:
Follow this video: ‪sam1174's Channel‬‏ - YouTube. You only need to go as far as removing the wood panel.
Then make sure the switch cluster is plugged into its cable.
Old Jul 16, 2011 | 07:47 AM
Beav's Avatar
When I first got my car my trip switches did not work. Later, through other work I was doing, I found the instrument cluster (speedo, tach, etc.) connector was not fully seated. I unplugged it for a few minutes, plugged it back in and everything began working as intended.
Old Jul 16, 2011 | 12:23 PM
OregonJag's Avatar
The buttons on the trip computer are very similar to those on your key fob; rubber pads that mash over some traces on a circuit board. My car came with one of the buttons mashed in and stuck. When I finally pulled it apart it had just mashed a plastic piece out of the way so it wouldn't work right.
If re-seating the plug on the back of the button cluster doesn't work, push the cluster out of it's holder. It pops out toward the driver after you squeeze the two tabs on the side. (DON"T take out the holder, it stays attached to the wood panel) Then open the cluster and clean the circuit board with rubbing alcohol the same way you would clean the circuit board on the key fob. It might help.
Skeeter
Sep 17, 2015 08:15 PM
adam699
Sep 12, 2015 05:32 PM
Busa R
Sep 10, 2015 07:28 PM
SCMike
Sep 9, 2015 09:30 AM
