4.2 Lower Pulley Upgrade
Old May 10, 2015 | 11:38 AM
Majik Lasers's Avatar
Default 4.2 Lower Pulley Upgrade
I called Eurotoys to order the upper and lower pulley package. Unfortunately the lower pulleys are out of stock for 2-3 weeks. I did some further research this morning and read that "the 4.2 engines already have a larger lower pulley...so the upper pulley is the only option before big time twin screw upgrade from Avos."
I couldn't find a single instance of anyone upgrading the lower on a 4.2.
Has anyone tried the Eurotoys lower pulley on a 4.2? What were the results? For $1000, I'd hope to see a noticeable improvement. Before I drop the loot, which I'm prepared to do immediately, I was hoping for some feedback from you guys. Thanks.
Old May 10, 2015 | 11:38 PM
Default Just to clarify
This is the lower pulley I was going to purchase.
http://www.eurotoysltd.com/catalog/p...oducts_id=1466
It says, "This supercharger pulley kit will give you a MAJOR power improvement of 50-60HP when coupled with 1 of our upper pulleys." but says nothing about the psi or performance of the lower by itself.
I've been searching on and off all day and still can't find a testimonial for this crank pulley on a 4.2...
mrplow58
Jan 21, 2024 05:53 AM
Johncy2000
Dec 22, 2017 04:32 PM
08Z06
Oct 24, 2015 05:46 PM
Ipc838
Sep 13, 2015 03:27 PM
rachelstr
Sep 3, 2015 12:59 PM
