50k
Old Nov 2, 2014 | 11:04 AM
mcook's Avatar
Default 50k
My '01 XK8 will soon hit the 50K miles mark, and I would like some general advice as to what I should be checking/adjusting/replacing when it does.
Old Nov 2, 2014 | 11:11 AM
test point's Avatar
Back in town? You don't drive the car enough!
Fuel filter, air filter, coolant, transmission fluid change and all the normal stuff by 60k. Most everything else is fix-it-when-it-breaks.
Ready for a lunch again?
Old Nov 2, 2014 | 11:19 AM
mcook's Avatar
Don't forget that I am out of town for 6 weeks at a time! Due home again on the 13th.
Thanks for the advice, I will get these jobs done. And yes, a lunch date should be on the near horizon.
Old Nov 3, 2014 | 08:44 AM
brgjag's Avatar
I would take a close look at the Tstat housing and the coolant reservoir tank, rad hoses for an signs of seepage. WHen I got my 03 I was getting whiffs of rad fluid smells and found the t-stat housing and the reservoir were leaking ever so slowly, leaving fluid residue on seams of the units. Check your rad hoses and other heater hoses for any BULGING.
aholbro1
Dec 29, 2024 06:46 PM
Arlo
XK120 XK140 XK150
Nov 1, 2015 05:44 PM
Etip
Oct 1, 2015 09:01 PM
Terry007
Sep 24, 2015 10:36 AM
Drew2006
Aug 28, 2015 04:22 PM
