97 XK8 convertible fog lights
Old Oct 13, 2013 | 11:28 PM
Jag happy's Avatar
Default 97 XK8 convertible fog lights
Bulbs were bad in the foglights. Bought new bulbs and installed them. Worked for just a few minutes and now will not come on at all. Checked for power with a test light and have none. Fuse in the boot is good. Any ideas?
Old Oct 14, 2013 | 02:46 AM
Next check the R2 relay:
Plenty of identical brown ones on the vehicle to use as a temporary substitute for checking.
Old Oct 17, 2013 | 02:32 PM
Jag happy's Avatar
I am stumped. The fuse is good, and the relay swap didn't help. I have not done anything in the boot to disturb the wiring. Lights worked for a short time and quit. Car was not moving but was just running in the garage. Checked at the bulb with a test light and there is no power. The light on the dash that shows when they are on is getting power. Any ideas?
Old Oct 18, 2013 | 03:33 AM
DevonDavid's Avatar
Not sure of this helps, and I have looked at the 1997 UK spec wiring diagram but .................. there's a relay and a fuse in the ** Engine Compartment ** fuse box ( #17).
The warning light gets power from the feed to the relay coil, but the lights are separately fused.
I can scan the relevant page for you if that helps, but check that fuse first.
Cheers,
David.
Old Oct 22, 2013 | 01:22 AM
Jag happy's Avatar
Thanks fellas. It was the fuse in the engine compartment fuse panel.
99xk8guy
Sep 29, 2025 10:51 PM
Jpav27
Jul 31, 2022 06:43 AM
kelliott
May 31, 2022 05:26 PM
obwoodie
Sep 3, 2015 07:45 PM
rachelstr
Sep 3, 2015 12:59 PM
