97 xk8 tachometer problem
Old Sep 22, 2014 | 08:31 AM
bartman28's Avatar
Default 97 xk8 tachometer problem
Tach will quit working while driving. Transmission will no go to low gear and if you put car on park the shifter will not come back out. . You shut car off and wait a few minutes it tach will work and will come out of park again
Old Sep 22, 2014 | 12:36 PM
Welcome to the forum bartman28,
I've moved your question from Jaguar Forums Feedback & Suggestion Center to XK8/XKR forum. Members here with the same model will be able to help.
Old Sep 22, 2014 | 02:21 PM
DevonDavid's Avatar
Do you *just* lose tacho, or speedo and engine temp as well plus an assortment of warning lights ? If so, it may be a CAN issue (the network that connects various modules and allows them to talk to each other). If not, then maybe a loose connection within the instrument module ?
The CAN runs through the gear select ("J Gate") module which is why the release solenoid is involved.
Old Sep 24, 2014 | 08:46 AM
bartman28's Avatar
I just lose tach and engine temp gauge. . Speedometer keeps working. .
toronadomike
Jan 22, 2026 10:13 PM
99xk8guy
Sep 29, 2025 10:51 PM
99xk8guy
May 28, 2024 09:36 PM
obwoodie
Sep 3, 2015 07:45 PM
laserguy
Sep 3, 2015 02:02 PM
