97 xk8 will not start
Old Jul 3, 2008 | 03:55 PM
test point's Avatar
Default RE: 97 xk8 will not start
I looked up all your codes and drew the potential conclusion that the engine overheated first. Several times the mention of low compression came up. Did the tech look at that? Do you have access to the JTIS DTC charts? They list the potential causes by each code.
Old Jul 3, 2008 | 07:22 PM
jag_genius's Avatar
sounds like your engine is extremly flooded.. i have had several.. cars coming from reputive jag shops.. and they can get it started.. and after 1 hr or 2 of babying the engine.. i finally get it started.. but if the walls of the cylinders have been washed down too many times.. then may need an engine..
have they check to see if the chains are intact? remove the cam covers and take a peek.
Old Jul 11, 2008 | 07:33 PM
ibjags's Avatar
buyer beware from ebay
i havea friend who purchased an s type motor and got burned big time
Old Jul 12, 2008 | 05:23 PM
hlgeorge's Avatar
Sounds like the old nikosil monster reared its head!
Old Jul 14, 2008 | 12:06 PM
Gus's Avatar
Gus
Go to my webpage and go to Nikasil and you may find the information you need. Good Luck!
99xk8guy
Sep 29, 2025 10:51 PM
99xk8guy
May 28, 2024 09:36 PM
JarodL
Mar 7, 2024 01:39 AM
Bones
Sep 8, 2015 08:34 PM
David Thompson
Sep 3, 2015 07:48 PM
