97xk8 paint code for charcoal metallic moulding windshield drip rails etc. Mine are p
Old Feb 1, 2026 | 03:52 PM
Turbofx's Avatar
Default 97xk8 paint code for charcoal metallic moulding windshield drip rails etc. Mine are p
Hopefully there is a paint code for the metallic Grey moldings or some
Would like to do the mouldings before paint
thing close
Old Feb 1, 2026 | 11:47 PM
Tha Driver's Avatar
Someone here will probably know the code, but... alternatives would be to take it to your local auto paint supply & they can shoot the trin & generate a formula, or... there are some spray-can wheel paints that are a very close match available at most any place that sells spray-can paint. Just make sure you thoroughly sand the parts down & use a good primer, & sand that before painting. Otherwise, the paint may pull off when you tape it to paint the car.
Old Feb 1, 2026 | 11:48 PM
Hell-Cat's Avatar
Dorchester Gray, I used a rattle can from Walmart, a perfect match.
https://www.walmart.com/ip/for-Jaguar-DORCHESTER-GRAY-METALLIC-342-Paint-My-Ride-Single-Stage-EZspray-Aerosol/9808922540?classType=REGULAR&from=/search
P
aint Code is 342/LDP
Old Feb 2, 2026 | 02:49 PM
jhuertas's Avatar
At a paint shop, they can measure the color with a colorimeter and mix the paint with near-perfect accuracy. You also need clear coat and proper surface preparation with the right abrasives, etc. (the list goes on, including a paint booth). But it is possible to paint it yourself; however, it won't be the same as a paint workshop. I took my XK8 to a paint workshop for a few imperfections; it's a task I haven't yet dared to attempt (yet). I have completed a course in automotive painting and I know that it is a complex task involving skill and technical equipment. However, in some places it is possible for the public to rent a paint booth by the hour to do this work ourselves.
Old Feb 2, 2026 | 04:41 PM
Hell-Cat's Avatar
Zaragoza ? Wow ! That is a beautiful place to live.
Ant Buck
Mar 28, 2023 01:11 PM
Blue340
24
Feb 8, 2022 12:41 PM
RA110623
Jan 8, 2022 08:07 AM
jazverina
E type ( XK-E )
May 20, 2021 07:15 PM
nycjaguar87
Oct 2, 2012 03:26 PM
