98 XKE engine stops when put in D or R problem
Old Mar 13, 2018 | 10:42 AM
shopcarpro's Avatar
Arrow 98 XKE engine stops when put in D or R problem
One of my battery terminals came loose while driving. Thereafter the car starts but when put into D or R the car judders and the engine stops. What could be the problem? Anyone has experienced this situation? Any deligent advise is much appreciated. I am also searching now, but so far nothing came up, hence posting for help. Thanx in advance for any help.
Old Mar 13, 2018 | 10:48 AM
Welcome to the forum shopcarpro,
I've moved your question from General Tech Help to XK8/XKR forum. Members here with the same model will be able to help.
Old Mar 13, 2018 | 10:57 AM
Johnken's Avatar
Shop Car, This is a good one. I wonder - what happens Car started in either neutral or park - Rev up the engine. . . Normal or stuttering/stalling?
I was leaning towards fuel supply as an issue that's why I asked about this one.
May we assume the battery is now fully charged and properly connected?
I wonder if a hard reset might help (disconnect terminals and touch + to - cables together for 30 seconds). I only thought of this because the interrupted battery connection may have played havoc with on board electronics.
John
Old Mar 13, 2018 | 12:15 PM
Gus's Avatar
Gus
A hard reset would be the first thing I would try then I would be checking for any OBDII codes and if you get any please post the codes. Also check that the battery is fully charged.
newguy12
Mar 11, 2013 08:01 PM
malibudav
XJ40 ( XJ81 )
Feb 29, 2012 12:20 AM
burmaz
Nov 13, 2011 05:29 PM
jagxkrtoofast
Sep 13, 2010 11:40 AM
