ABS & ASC Tracking Not Working Amber Warning Light
Old Sep 15, 2017 | 07:20 PM
jaguar51's Avatar
Exclamation ABS & ASC Tracking Not Working Amber Warning Light
Greetings,
Any idea's why and how too address the ABS warning light coupled with ASC tracking not working / amber warning light activated? Possibly associated with TB Sensor or wheel sensor?
ER
Old Sep 15, 2017 | 07:44 PM
jaguar51's Avatar
The ABS Brake and ASC tracking not working/Amber warning lights came on just after I washed the vehicle, did a wheel sensor get wet causing the above issue?
Old Sep 15, 2017 | 08:09 PM
RJ237's Avatar
You can start by unplugging the wheel sensors and spraying the connectors with electronic cleaner. Then clean the sensors and toothed ring without removing the sensors as they get brittle with age.
Then start and drive a couple of short trips. If the lights don't go out the best choice is to find a shop ( not dealer) that can read jag specific codes and comeback here with the actual codes for more help.
Old Sep 16, 2017 | 04:11 AM
jaguar51's Avatar
Smile
Very good, thank you...
ER
