abs brakes
Old Jun 10, 2014 | 08:11 AM
tony bosco's Avatar
Cool abs brakes
hello forum, is there an abs sensor on every wheel and how do i figure out which one is bad.... ( abs light comes on and off intermittently ) is there a part# and where can i get sensors for a decent price... is it a tough job.... ??? helpppp thanks.
Old Jun 10, 2014 | 08:23 AM
RJ237's Avatar
Yes, there is a sensor on each wheel. They hardly ever fail, but may need cleaning. The connecting cable is often the cause of a fault due to a broken wire that opens when turning the steering wheel or the suspension flexes. There is lot of information on the forum on this subject if you do a search or check out the DIY sticky near the top of the forum page.
Here is a sheet from the jagrepair.com with some information, there is a lot more available there, including videos on cleaning and repair.
http://jagrepair.com/images/AutoRepa...heet%20XK8.pdf
Old Jun 10, 2014 | 03:27 PM
tony bosco's Avatar
Cool abs brakes
thanks RJ237... still getting use to the forum and where to find things... tks again .... tony
ericjansen
Dec 19, 2021 12:20 AM
British Ride
XJ40 ( XJ81 )
Nov 28, 2015 03:50 PM
flyrr100
Sep 29, 2015 03:47 PM
xjrjag
Sep 24, 2015 10:08 PM
