ABS Control Module - C1095 Pump Motor Circuit Failure
Old Sep 19, 2017 | 05:35 PM
djpxk8's Avatar
Unhappy ABS Control Module - C1095 Pump Motor Circuit Failure
I have the yellow light warning says "Trac not available"
I cleaned all the speed sensors to no avail.
My ODB reader, under the "ABS Control Module" section, gives me a C1095 - Pump motor circuit failure
Is it likely that the "power connectors" have a dry joint and need soldering (in the ABS Control Module" ) is one of the problems I have read about.
Does anyone have any suggestions as to which pump motor it is referring to ?and where it might be? Is it more likely to need a new ABS Control Module?
Any help would be greatly appreciated, regards David
Old Sep 19, 2017 | 06:01 PM
RJ237's Avatar
You don't need a new module, just a solder repair. The ABS pump plugs into the module and it's the pins for that connection that are at fault. I believe the procedure can be found in the DIY sticky or at jagrepair.com.
Old Sep 19, 2017 | 06:20 PM
Gus's Avatar
Gus
This link should help
Old Sep 19, 2017 | 09:03 PM
djpxk8's Avatar
RJ237 & Gus, thank you very much for your help and information!
