ABS Module Differences?
Subscribe
Apr 11, 2014 | 03:15 AM
What is the difference between the ABS Modul LNF 2210 AD and LNF 2210AC?
Both were used in XJ8 and XK8 Models.
Are they interchangeable? Thanks
Daniel
Reply 0
Apr 11, 2014 | 08:57 AM
dont know yet, my advice with modules, send yours out to have fixed. I fixed my own.These cars love to tell you, "incompatible part" when yuo start swapping modules by the way, and with no return on electrical parts, im good
Reply 1
Apr 11, 2014 | 09:01 AM
There have been several threads discussing substitution. Without knowing the specifics of the two you are looking at, the AD is the next version and should be able to replace the AC. But with abs modules, there isn't that much difference as long as they have the same number of solenoids.
Early model cars have six solenoids, while later models with traction control have nine. Obviously, they are not interchangeable.
Reply 1
Apr 12, 2014 | 03:22 AM
Thanks for your replies.
Can I see the difference between 6 and 8 Solenoid from outside (mounted on car)?
Daniel
Reply 0
Apr 12, 2014 | 06:11 AM
Not obvious from the outside, but if the car has traction control there are nine solenoids.
Reply 0
Subscribe
Currently Active Users (1)
