abs traction control fail and stability control fail continuing
Old Aug 23, 2012 | 08:33 AM
adriano70's Avatar
Default abs traction control fail and stability control fail continuing
HI guys,
I have this problem on starting the car up. I have read the other posts on this and removed and cleaned all sensors and replaced the driver side abs sensor but the problem is still occuring. Revernd Sam had a link to check the solder points but this link no longer seems to work so I havent been able to try that.
Has anyone anymore idea on what the problem could be?
Thanks in advance
Adrian
Old Aug 23, 2012 | 08:52 AM
RJ237's Avatar
http://jagrepair.com/images/AutoRepa...e%20Repair.pdf
Try this one. You can also send the module out for repair for a little over $50. Do a search on the forum also, someone effected the repair by drilling a hole in the case and soldering the posts.
RJ____________________
97 XK8 86K mi
Old Aug 23, 2012 | 08:54 AM
steveinfrance's Avatar
There's a link in the HOW TO in this section
https://www.jaguarforums.com/forum/x...ts-data-29800/
Scroll down to alphabetic list and it's the first item
Matei Dima
Oct 8, 2015 11:45 AM
JeffinSwitz
Sep 16, 2015 01:44 PM
jaguarbill
Sep 5, 2015 11:43 AM
pocketrocket
Sep 3, 2015 07:44 PM
XFR_Gold
Sep 2, 2015 12:24 PM
