ACC with mesh grille
Old May 25, 2014 | 07:09 AM
CougCol's Avatar
Default ACC with mesh grille
Hi. In the middle of installing a mesh grille & its occurred to me that the Adaptive Cruise Control radar (mounted underneath the black nose bar to the left as viewed from the front - UK) might not work?
Does this therefore need to be moved either to the bottom opening (2005 XK8) or behind the bumper itself (assuming it works through the plastic nose)?
Any advice would be appreciated as I have come to an unplanned stop!
Old May 25, 2014 | 08:22 AM
Dennis07's Avatar
I don't know the particulars of this system but generally speaking ...
Unless the wavelength of the radar signal is small compared to the mesh openings, it probably won't work through the grill. Does your documentation tell you anything about the frequency band this thingy works in?
Old May 25, 2014 | 08:46 AM
ccfulton's Avatar
XKRs had a mesh grill as standard and most mesh grills are more or less the same as those when it comes to the wire spacing,etc. Unless you have a very unusual one off then I doubt it will be an issue.
Old May 25, 2014 | 09:30 AM
CougCol's Avatar
Thanks guys.
No information on the systems particulars at all I'm afraid.
This answers my question though; give it a whirl & see what happens!
I'll post here the result for others anyway.
Old May 25, 2014 | 01:16 PM
CougCol's Avatar
Yep, works a treat so the grille is no problem.
Thanks again
radiatn
Jul 2, 2021 04:45 PM
Quantico
Oct 13, 2015 10:34 PM
Col. Sandurz
Sep 28, 2015 07:29 PM
picard
Sep 19, 2015 08:13 PM
