Accessory Supply Socket in Boot
Old Feb 24, 2018 | 08:54 PM
Pristine97XK8Convertible's Avatar
Default Accessory Supply Socket in Boot
Two empty sockets by the battery. Which one is the Accessory Supply socket? Please help identify.
Old Feb 24, 2018 | 08:59 PM
Gus's Avatar
Gus
See if this helps JagRepair.com - Jaguar Repair Information Resource
Old Feb 25, 2018 | 05:16 AM
astromorg's Avatar
it's the Black connector to the right of the photo. Black wire is Ground, Brown/Green wire is permanent live and White/Red is ignition switched live.
For the switched live, you'll need a standard relay in the centre position of the three relay sockets lined across the car in the Trunk Fuse Box and a 20A fuse in F11 of that fuse panel.
For the permanent live there's a 10A fuse in F17 in the Driver's side fuse panel.
Old Feb 28, 2018 | 01:14 PM
Thank you so much astromorg for your detailed description.
Now I realize the Accessory Supply Socket is meant to be used in conjunction with part number C2A1403 Auxiliary Power Socket which comes with various socketed cable harnesses and what is essentially a cigarette lighter socket with spring-loaded cover. I understand C2A1403 is no longer available, so we have to do some wire cutting and splicing.
Just to make a small clarification on the wire colors:
  1. B Black
  2. NLG is Brown w/LightGeen
  3. PN is Purple w/Brown
Cheers !
Old Feb 28, 2018 | 05:15 PM
astromorg's Avatar
Sorry about the colours. Early X100s had the colour scheme you describe, but I inadvertently overlooked your 97MY. Apologies for that.
Standard insulated Lucar type connectors will plug onto each of the three terminals in the accessory socket.
Flighty
Oct 6, 2014 11:55 AM
Alan-the-ifa
Mar 28, 2014 03:39 PM
jaguarcraver
Dec 25, 2013 04:18 AM
dennisw
Nov 20, 2012 01:05 PM
malibudav
XJ40 ( XJ81 )
Mar 2, 2012 11:03 AM
