Adamesh exhaust clearance
Old Oct 5, 2017 | 08:52 AM
p-Rock's Avatar
Default Adamesh exhaust clearance
Hey all,
Has anyone else that used the full adamesh kit noticed the clearance to the ground from the pipes that come from the main front muffler? These lowering springs are going to cause it to hit the ground for sure. I dont understand how anyone else has not run into this.
thanks
Old Oct 5, 2017 | 01:54 PM
phanc60844's Avatar
The adamesh system is no lower than stock, maybe you should release the pipe clamps and push the system up a bit to give the clearance you need
Old Oct 6, 2017 | 04:20 PM
p-Rock's Avatar
Ill tell you one thing for sure it definitely does have drone in the cabin. Sounds good on the outside though
