Advice on winter storage
Old Oct 13, 2017 | 02:06 PM
Barry_Tucker's Avatar
Thanks for the tips
Old Nov 18, 2018 | 03:33 PM
GhostRider9000's Avatar
found my answer.
Old Nov 20, 2018 | 10:26 PM
zray's Avatar
If winter humidity is over 50%, then keep a dehumidifier plugged in all winter long.
Z
Old Nov 21, 2018 | 07:00 AM
A normal 'household' dehumidifier is limited in the amount of moisture it can remove by the temperature of the surrounding air. At 20C it can reduced the humidity level to 40-45% but at 10C the limit rises to the 60% range. If your car is in an unheated garage in a relatively cold area ( < -5C ) a dehumidifier will do bugger all.
Old Nov 21, 2018 | 08:14 AM
zray's Avatar
You are right about the household type dehumidifier, mine work pretty good down to 25-30 F then not much is going to happen,
however there are commercial - residential duty dehumidifiers are available that can be a stand alone unit or work in conjunction with a central HVAC system, some are made specifically for garage duty that will work below freezing if necessary.
Fortunately, really cold conditions are also often low humidity.
Z
