Air Bag Warning
Old Aug 25, 2025 | 05:04 AM
dsimo7's Avatar
Default Air Bag Warning
Hello everyone. I've got the airbag warning light on my 2002 XKR. It goes on, then off and then flashes eight times. According to information I gleaned from earlier posts, this is a code 18 which means "Pass airbag deactivate lamp circuit fault." Assuming I'm reading this correctly, where is the best place to start to track this down?
Old Aug 25, 2025 | 07:20 AM
Einhead's Avatar
If i remeber it correctly, the car will warn you the lamp itself goes out.. does the passenger lamp come on at any time? It should come on breifly when you turn on the ignition. If it does not, start with replacing the bulb.
/E
Old Aug 26, 2025 | 03:58 AM
Orthodixie's Avatar
Experiencing the same issue on my ‘04. Have had it 3 times since 2017. Just showed up again recently.. Don fixed it each time by removing the passenger seat and cleaning the connector. I am not comfortable playing either the little guy however. Please keep us apprised of what you do.
Old Aug 26, 2025 | 10:05 AM
dsimo7's Avatar
Thanks. I'll check the bulb and advise
DaveE
May 26, 2018 03:12 PM
AltonJag
Mar 11, 2018 10:20 AM
steveconnop
Sep 26, 2017 01:06 AM
Timsjag
Aug 19, 2013 12:27 PM
chazaroo
Aug 9, 2013 05:06 PM
