Air Con Wiring MY1999
Old Jan 4, 2017 | 02:57 PM
Davedavies's Avatar
Default Air Con Wiring MY1999
Hi All,
Just looking for some info about the wiring for the air conditioning trinary switch.
I have a pressure switch assembly with 5 pins (must say at this pont it has come from an XK8 but going onto a DB7).
The electrical connector is completely different from the Aston plug but the switch function is suitable with some small wiring modifications and the various pressure settings are suitable also.
I have a wiring diagram from the XK8 workshop manual but what I dont have is the pin layout for this 5 pin connector.
Could someone upload a photo of the harness showing it plugged into this switch or attached a simple schematic of the connector.
I can see the connector ref on the wiring diagrams is LF57 if this helps.
Thanks in advance and hoping someone can assist.
Dave
Old Jan 4, 2017 | 04:24 PM
Gus's Avatar
Gus
This should help.
Link. http://www.jagrepair.com/images/AutoRepairPhotos/jagxk1999.pdf
Gus
www.jagrepair.com
Old Jan 4, 2017 | 04:31 PM
Davedavies's Avatar
Hi Gus,
thanks for the link, I have this manual - this is how I found the wiring diagram.
What I need is to know which of the pins is no 1,2,3,4 and 5 in the connector.
I only have the switch so dont know which pin is which as the switch doesn not identify the termnal designation on the housing.
Dave
Old Jan 4, 2017 | 05:28 PM
Gus's Avatar
Gus
I have my car on the lift now. I will see if I can get a photo. You want to know the color code and position of the wires to the pressure switch plug correct?
Old Jan 4, 2017 | 05:42 PM
Davedavies's Avatar
Hi Gus,
Yes please, that would be great
I know the wires according to the manual are as follows:
Black - pin 2
Black - pin 4
Blue/Black - pin 5
White/blue - pin 1
Yellow/white - pin 3
I just need to know which wire goes into which location on the plug.
Thanks again
Dave
Old Jan 4, 2017 | 07:28 PM
Gus's Avatar
Gus
In this photo you are looking at the back of the plug the lock clip is on the other side. It is the side that faces the radiator / front of the car.
Yellow/White strip – Black/Pink strip – White/Blue strip
Open – Black/Blue stripe – Red/Green stripe
I hope this helps!
Old Jan 4, 2017 | 07:31 PM
Gus's Avatar
Gus
Second time on the photo
Old Jan 4, 2017 | 07:40 PM
Davedavies's Avatar
Hi Gus
thats absolutely great. Thanks so much for your help.
Its a pity the subscribers to the Aston Martin forums aren't as helpful.
Thanks again
dave
Old Jan 4, 2017 | 07:46 PM
Gus's Avatar
Gus
Any Time! Visit my page when you can..
