Air Conditioner Issues
Old Sep 7, 2014 | 10:38 AM
Old_Doc's Avatar
Default Air Conditioner Issues
My 2002 XK8 (44000 mi) works fine for first 20 minutes or so after startup then blows cool (not hot or cold) air. I id have the system charged. Checked fault codes and got the following
14 Water temperature input malfunction Instrument cluster output Refer to PDU
23 Refrigerant pressure switch malfunction Harness / connector fault Switch open / short circuit Refer to PDU23 Refrigerant pressure low refrigerant charge *Leak from damaged pipe or joint Rectify as required and recharge system
44 Defrost vent motor fault Harness / connector fault Servo motor seized or sticking Flap seized or sticking Refer to PDU
45 Centre vent motor fault Harness / connector fault Servo motor seized or sticking Flap seized or sticking Refer to PDU
46 Foot vent motor fault Harness / connector fault Servo motor seized or sticking Flap seized or sticking Refer to PDU
Old Sep 8, 2014 | 06:45 AM
jamdmyers's Avatar
Have you checked your fuses ?
Old Sep 8, 2014 | 07:49 AM
As you have had the system recharged and there are presumably no leaks, fault 23 should no longer apply.
The AC (heater) Unit has two Servo Motors on the LH side (items 2 and 3):
These motors move the flaps to redirect the airflow. Two faults are known:
1. sticking
2. seals breaking up preventing proper closure
This covers faults 44, 45 and 46. The flap positions only affect airflow - they do not affect temperature. A regular for causing cabin temperature issues is a blocked In Car Aspirator. This is behind the small grille in the dash panel:
It collects dust and sends false signals to the AC Module.
Instead of leaving the AC permanently on the preferred settings, a good preventative maintenance routine is to cycle the system through MAX hot to MAX cold and airflow from screen to footwell on a monthly basis. This helps prevent any of the control valves and flaps sticking.
Old Sep 8, 2014 | 03:07 PM
Old_Doc's Avatar
Is there some way to clean aspirator without taking dash board apart? Perhaps vacuuming.
Old Sep 28, 2014 | 09:27 AM
Old_Doc's Avatar
Default Thanks GGG
I exercised my AC for several days as suggested and it now seems to work. Went out yesterday to "leaf peep" and it blew cold all day.
99xk8guy
Sep 29, 2025 10:51 PM
JarodL
Mar 7, 2024 01:39 AM
Kevin Burnaby
Jun 28, 2020 08:04 AM
redrover41
23
Sep 25, 2015 01:33 PM
OkieTim
Sep 2, 2015 12:48 PM
