Airbag error code 12
Old Jul 22, 2013 | 11:43 AM
mattyhurd's Avatar
Default Airbag error code 12
Hi I am getting the error code 12 (1 flash then a pause then 2 flashes of air bag)
I am struggling to find out what this error means.
It appeared after I had a host of electrical problems due to a flat battery, upon changing the battery and doing a hard reset it has appeared, all other problems have been fixed by the new battery but this one
Any help would be greatly appreciated
Many thanks
Matthew
Old Jul 22, 2013 | 01:05 PM
Flash Code 12 = Restraint Control Module - Internal Failure
That sounds frighteningly expensive but note 'battery voltage out of range' is one of the possible causes. Eliminating this first seems a good way to start troubleshooting.
Old Jul 23, 2013 | 01:44 AM
PaulsXK8's Avatar
Default My code 12 fix
When I had an error code 12, it turned out to be a broken wire under the driver's seat. They get caught in the track and break. There are other posts on the forum that show where the break is. Good luck!
Old Nov 22, 2017 | 04:54 AM
fishman's Avatar
Many thanks
Matthew
Hi,
How did you manage to FIX it?
Br, Marcin.
Bcrary3
Feb 21, 2023 04:29 AM
Jpav27
Jul 31, 2022 06:43 AM
Terry H
Jul 4, 2017 05:48 PM
KarimPA
Sep 27, 2015 08:46 AM
tonyforman
Sep 10, 2015 07:23 PM
