Airbag warning light
Old Aug 15, 2015 | 04:01 PM
tberry6686's Avatar
Default Airbag warning light
Hi Guys
Just trying to find out where I should look at first with my airbag warning light.
Basically, Light is comming on intermittently (every time I drive it but sometimes after 30 sconds, some times after 30 mins).
I suspect an iffy connection somewhere but not sure where the connections are. Flash code is 19 and OBD code is B2293. The stickies list various possibilities for this flash code but I was wondering if one or 2 are most likely and where to find the connections.
Old Aug 16, 2015 | 03:13 PM
max224's Avatar
There are two sensors just behind the front grille to trigger the airbags; you might want to check the connections on those. Just be sure to disconnect the battery first and wait awhile for the various electrical components to discharge before you start. You DO NOT want to trigger the airbags.
Old Aug 17, 2015 | 11:35 AM
daro31's Avatar
After trying all of the suggestions on the forum, I solved my mine by removing the drivers seat and fastening and unfastening the big yellow connector under the seat and then the big yellow plug that is half way up the seat back on the outboard side.
I had to pull the seat back cover more than half way off so I found it much easier to take the seat out to do the job. As others have said disconnect the battery.
99xk8guy
May 28, 2024 09:36 PM
D.K
Dec 10, 2023 02:05 AM
Jpav27
Jul 31, 2022 06:43 AM
AL NZ
Sep 4, 2015 08:39 PM
edtexas
Sep 4, 2015 08:20 PM
