Airbag warning light after hard reset
Old Oct 5, 2014 | 11:24 AM
looops's Avatar
Default Airbag warning light after hard reset
Hello everyone.
After hard resetting to try to fix the remote boot opening function (didn't fix it) the airbag warning is showing.
Also I can't recode the remote using the key-flash-key 1 position - flash 4 times procedure.
Any ideas?
Paul.
1996 XK8 Coupe.
Old Oct 6, 2014 | 05:30 PM
H20boy's Avatar
One electrical issue at a time, my friend
The air bag warning first - count the flash 'code' when you turn the key...could be a 2-3 which is a two short flashes, pause, then three short flashes, then it repeats 5 times before staying illuminated. That code tells you where to look. The forum has several threads with those codes listed if you want to look first before you post back here with your particular flash sequence. g'luck!
Old Oct 7, 2014 | 09:24 AM
looops's Avatar
Update: It's working fine. Solution: Fixed itself. Magic pixies I think.
JarodL
Mar 7, 2024 01:39 AM
D.K
Dec 10, 2023 02:05 AM
Jpav27
Jul 31, 2022 06:43 AM
AL NZ
Sep 4, 2015 08:39 PM
edtexas
Sep 4, 2015 08:20 PM
