Alloy Wheels Upgrade?
Old May 19, 2009 | 10:38 AM
Raheny's Avatar
Default Alloy Wheels Upgrade?
Hi All,
I have stock 17" Lamina wheels on my 2001 XK8 and am tempted to upgrade to the 19" Apollos that became an option from 2002 (they're by far my favourite Jag alloy design). Does anyone know if I will be able to fit these to my 2001 XK8 before I go ahead and purchase?
I understand the Laminas are 8J x 17" while the apollo are 9J x 19" at the rear (8J at front). Does that matter? Excuse my ignorance!
I believe the wheel nut configuration is the same for all MK I XK8s.
Jonathan
Old May 19, 2009 | 12:20 PM
ABorealis's Avatar
Default Rim sizes
Not a problem, you can even go up to the 20" rims that appeared later. Just ensure you use the correct tire recommendations and there will be minimal difference in the overall circumference of the wheels. Also, it is correct to have narrower rims on the front hence the staggered size wheels.
Apollos's ARE nice but I prefer the Perseus 20's!
Old May 19, 2009 | 03:49 PM
Raheny's Avatar
I presume the tyre size for 19" wheels is 245/40/19. Minimum speed rating of W and minimum load rating of 96?
Old May 19, 2009 | 04:10 PM
wazari's Avatar
If you are going to run 8 and 9's, you should run 255-40-19 in front and 275-35-19 in the rears. 245-40-19 would be a little short compared to the OD.
Old May 26, 2009 | 08:49 AM
Raheny's Avatar
Thanks for the info. Much appreciated. Think I will go with the 19". Apparently the Apollos are no longer produced, so I'm looking at the Atlas type now.
Old May 27, 2009 | 01:09 AM
H20boy's Avatar
I agree with you Raheny, love the look of the 19" apollos! I've seen a few show up on ebay over the last year, and you may be able to use Ken (ken@britishparts) or Andy (jagtechohio) to see if they can find you any also.
BTW, stock front and rear tire sizes on the staggared 19's are 245/40 and 255/40, respectively.
dsnyder586
Dec 29, 2024 07:39 PM
Rivguy
Dec 4, 2020 07:55 AM
PMKimpton
Aug 3, 2019 08:22 PM
lickahotskillet
Oct 18, 2015 09:51 AM
lickahotskillet
Sep 11, 2015 07:54 PM
