Alpine “No FM” on radio
2003 XK8, Alpine/upgraded radio with no mods, CD changer in trunk, etc.
Just started getting a “No FM” readout on the little screen, and there is ..no..FM. AM, cassette, work fine, speakers fine, buttons etc all work fine, but. no FM sound at all, not even speaker hiss.
The antenna goes up and down ok.
No intrusive work work has been done in the trunk. I recently had the passenger seat belt receptacle replaced, which required removal of the front seat, but mechanic says nothing otherwise was done.
Any ideas?
TIA,
Caris
Any ideas?
TIA,
Caris
Think we've seen this before. If you push the zero button you move the FM to a different set of stored stations, those automatically stored by the unit as the 9 strongest "local" signals.
If nothing stored you get that message.
Try pressing the zero button to bring up your normal FM mode.
John
John
CatLovr (03-09-2019)
Thanks - it was the simple Press 0 to bring up memory settings. I took time to set stations in both A and P. This hadn’t happened before, obviously, so I appreciate the kind advice.
I don’t have the Audio Handbook so could not RTFM.
Spent all afternoon cleaning and conditioning the entire cabin. Hopefully the leather conditioner will help out my dry skin.
cheers, y’all.
cheers, y’all.
The following 3 users liked this post by CatLovr:
