anyone like to try out my module
Old Mar 23, 2016 | 08:54 PM
stevepaa's Avatar
Default anyone like to try out my module
So my security module is acting strange in that it will not operate the top.
https://www.jaguarforums.com/forum/x...ioning-159729/
So would anyone volunteer to have me send them mine and try it out in their car to see if it is faulty. If it works in your car then I will have to look at my instrument pack for the errors.
module pn is LJE2600AB/015
Old Mar 23, 2016 | 09:14 PM
Gus's Avatar
Gus
Call ASI and see if they can test it for you.
Link.http://www.autoecu.com/index.php?p=1
Gus
www.jagrepair.com
Old Mar 24, 2016 | 09:48 AM
stevepaa's Avatar
ASI can not test it for top operation signals
Old Mar 24, 2016 | 01:36 PM
stevepaa's Avatar
well, somehow it started to work using the outside key method and then the rocker switch worked and then nothing and my back windows are down
I am beginning to think my problem is with one of the 5 micro-switches, 2 on the cylinder and 3 around the latch mechanism.
Old Mar 24, 2016 | 06:31 PM
Gus's Avatar
Gus
The windows dropping tells me that the switch in the ram is correct and along with that the switches in the header are correct. Not sure what is taking place but from what you are saying I do not believe it is a switch but I will look at it again.
Gus
www.jagrepair.com
Old Mar 24, 2016 | 10:33 PM
stevepaa's Avatar
thanks, Gus
I am going to check for continuity on them tomorrow.
MC36
US Lower Atlantic
Mar 29, 2016 07:11 AM
Cadillac
Mar 24, 2016 09:04 AM
XJSV12a
Mar 21, 2016 10:36 AM
