ASC fault cured
Old Jun 19, 2015 | 01:41 PM
Gibso's Avatar
Default ASC fault cured
Hi everyone.
I have been reading all the posts on ASC. There has been lots of helpful directions and tests. All to no avail. I thank all for their posts.
My problem: Slight surging when in Cruise Control. Not enough to move the speedometer or tachometer just an awareness of surges. Then as driving, in Cruise Control or normal, ASC and amber light. Car goes to Fail Safe. Fault goes off and car accelerates again. Repeats randomly.
Codes: Codes from 'Gearbox ratio wrong' to C1165. This last code is for faulty RH rear speed sensor or wiring.
FIX:I removed the RH rear wheel and inspected and tested the sensor and wiring. All ok. Wondered how clean the sensor ring was. Put a flat blade screwdriver down the sensor hole to check for dirt.
The sensor ring was loose.
Removed hub bearing nut and lowered hub out of drive shaft. Ring was worn on center hole. Ran small bead of weld on center hole and ground to a tight fit. Re assembled drive shaft and hub. Test drove all ok so far.
Question: What should the torque setting be on the hub main nut be.
Thanks.
Old Jun 19, 2015 | 02:29 PM
RJ237's Avatar
I believe it is essential to use a new nut as it's deformed when torqued and will come loose if reused. The torque is 304-336 Nm.
Old Jun 19, 2015 | 02:49 PM
zidjan's Avatar
Originally Posted by Gibso
Hi everyone.
Thanks.
I am having the same issue as yours....the car is in the shop now as I tried to check it myself..I won't know what I am doing...so I hope that my problem is as simple as yours.
Old Jun 19, 2015 | 03:33 PM
Gibso's Avatar
Thanks RJ237.
Looks like a trip to the Jaguar dealer. First ever. Do not know where they are yet.
Will go in with $15 in my pocket and no credit cards.
Old Jun 19, 2015 | 06:59 PM
mrplow58's Avatar
Thanks RJ237.
I tried that once at my dealer and I was given a coffee cup, and a bag of TownHouse crackers. These guys are serious about getting their $170 flat rate time. I just got my X Type, and needed some air in my LF tire, so I could make it home, 20 miles away. I ended up walking across the street, and buying a can of Fix a Flat, and made my way back home. I have dreams of burning the dealer to the ground, but I don't break laws. But to dream....ahhhhhh.....Be cool.....Mike
Old Jun 19, 2015 | 09:07 PM
Jandreu's Avatar
Nice repair, I too have the very, very slight surging while on cruse control, usually down hill but no codes or issues.
Old Jun 28, 2015 | 01:04 AM
Sir Alex of Yotto's Avatar
Remember how many ASC failures are due to cracked solder joints inside the ASC control module? Judging by the pictures I've seen of this problem, I'd guess that those oft-cracked solder joints are the power supply for the module's PCB (printed circuit board).
If memory serves (someone please correct me if memory is not serving), the effect of this solder joint failure is the 'ASC not available' and 'TRAC not available' being displayed, and the AMBER warning light illuminating...but nothing else of consequence happens (AFAIK).
Now, it is apparent from this thread and others that a split or loose ABS (reluctor) ring causes a plethora of trouble codes and what appear to be actual transmission failure(s) of some kind...
This has me wondering; could one test (AND temporarily bypass) this scary and confounding problem by disconnecting the plug at the ABS module in the engine compartment?
If so, it would verify that: A) this weird problem is related to the ABS system, and not a transmission (or other) problem, and, b) temporarily banish this problem with only the loss of ABS and traction control, leaving the car completely driveable (BTW, I've never had a car before with either one, so I don't miss them at all).
Old Jun 28, 2015 | 07:47 AM
Gibso's Avatar
I will disconnect the brake unit and see what happens. My system is working fine. As the unit is on the serial bus I am expecting mass faults. If I connect the serial bus through then at least I expect brake system faults.
As for not needing these systems I am not so sure. Yes being older I have driven sports cars by the seat of my pants. But I like ABS. I like traction control and yes I like ASC. I drive in Florida and during downpours I see the ASC system come on, signaled by ASC message and flashing of the amber lite, the car accelerates away as smooth as on dry roads. Having exciting moments might be appealing to some but I prefer to relax enjoy the ride.
Old Jun 28, 2015 | 02:08 PM
Gibso,
I thought, from reading post #1, that taking care of the loose ring fixed your problem already? (not including question about the hub main nut). Are all of the trouble codes gone now? If so, there is no need to disconnect the ABS control module for testing purposes. Apologies if I have missed something in the conversation.
We just had a torrential downpour here (I live a couple hours south of you, near West Palm Beach), so I know what you are talking about insofar as driving in heavy rain; in fact, when I was driving back from Naples where I bought my XK8, I ran into rain so heavy I couldn't see 30 feet in front of me on Alligator Alley and had to pull off the road for about 20 minutes until it let up.
However, it wouldn't surprise me if I were one of the most conservative drivers on this forum (or on the road generally). Being older myself (hate saying that), and never having had a car with antilock brakes and traction control myself, I guess I have always "driven by the seat of my pants", but since I drive pretty conservatively anyway, haven't really needed these features too much.
There is no denying that they are practical, or even necessary, for some driving styles. But if, IF, temporarily disabling them will allow the car to be driven 'normally' (but sans ABS and TRAC), and possibly save someone a trip to the Jaguar dealership and/or being towed, well...
It's always good to have options.
JaguarLover101
48
Jun 12, 2023 10:28 AM
bdboyle
Sep 16, 2019 05:58 PM
Johnken
Apr 8, 2018 10:21 AM
dmatthewman
Sep 30, 2015 10:10 AM
