asc/trac lights on.
Old Feb 2, 2025 | 06:40 AM
Ant Buck's Avatar
Default asc/trac lights on.
Put the battery back on and was greeted with the above unavailable message. I went for a good run and then had a gearbox fault message(holding in second gear)got home at a very steady pace. fired her up again, gearbox fault gone (shifting as it should) but asc/trac still on. Any ideas? Many thanks. Anthony.
Old Feb 2, 2025 | 07:33 AM
Jon89's Avatar
First things first -- how old is your battery?
Old Feb 2, 2025 | 08:34 AM
Ant Buck's Avatar
I put it on about two years ago,it's a varta. Do you think it could voltage related?.
Old Feb 2, 2025 | 10:31 AM
bladerunner919's Avatar
Possibly. Do you have a voltmeter?
Old Feb 2, 2025 | 10:52 AM
Ant Buck's Avatar
I have checked it,12,1 volts.
Old Feb 2, 2025 | 11:03 AM
zray's Avatar
that’s low.
put the battery in a charger. It should be 12.6 v after sitting overnight without the charger or battery tender connected.
it does help to banish gremlins to keep the car on a battery tender whenever the car is not being used overnight or longer.
do you have a list of the OBD-II codes that are present ?
Z
Old Feb 2, 2025 | 11:05 AM
Ant Buck's Avatar
Thanks i will do that.
trainfan
Jul 2, 2022 06:29 PM
jrdelohery
May 19, 2021 11:02 PM
rht54
Mar 1, 2016 07:03 AM
mjlaris
Aug 26, 2011 12:07 PM
okistag
Aug 9, 2010 04:02 AM
