Auto adjustment
Old Jun 19, 2009 | 08:56 PM
hlgeorge's Avatar
Question Auto adjustment
Does which key/key fob you use effect which memory button the auto control for the seat and steering wheel adjust to when you put the key into the ignition? I just replaced the tilt motor in my steering wheel and this is the first time it has worked properly since I have had the car. I set the memory button #1, but the auto return seems to go to the memory button #2 setting when I insert the key into the ignition.
Old Jun 19, 2009 | 09:10 PM
test point's Avatar
On three other Ford products I own the key fob determines the seat position of the driver that is opening the door but I do not think it does on the Jag u ar or at least I have not set mine up correctly to access that option.
MrWhite
19
Jun 14, 2022 07:49 PM
danke
Oct 3, 2015 09:31 PM
3jagfamily
Oct 1, 2015 01:49 AM
Lord_Rowan
Oct 1, 2015 01:45 AM
MrWhite
Oct 1, 2015 01:43 AM
